Re: power trim/classic fifty/1986
I have the same problem. My tilt/trim just clicks. I have an old trim/tilt assy, the hydraulic reservoir is located inside the boat. Anyway, the problem with mine is the trim motor. My dealer had it rebulit and in the process of installing right now. Hopefully everything works. It's costing me 250.00 for the rebuild, plus removal and installation.<br /><br />There some advice that I saw that say check the solenoids. One for up and one down. It's not likely that both of them would go bad at the same time so my guess is it's your trim motor. Hope this helps.
