Power trim cylinder
MyBad
I want to check the trim cylinder fluid on my 89 5.0 cobra. The OEM manual states to raise the drive in full tilt position. Should I support the drive in full tilt, before opening the reservoir, before checking the fluid?
Any other "cautions" I should take before opening it?
Thx MB
Re: Power trim cylinder
Thx MB
Nope,... The weight of the drive is supported by the valvin', not the reservoir cap....
MyBad
Thank you sir very much....I have "for now" all issues with the boat resolved.....thanks in large part to the help I have received here.
MB
Michigan Ted
So you run the trim all the way up to check and fill the reservoir? Didn't know that. What oil do you use, transmission fluid?
MyBad
Mine [according to my manual] calls for OMC Power Trim/Tilt or Dextron II auto trans fluid, which is what I used.
MB
