shwoop_soobie
Thread starter- Joined
- Mar 11, 2010
- 80
so i have been sorting out some power trim issues... and while cleaning nasty old oil/grease i found a sticker... from what my research shows it came off of the power trim unit... it says something about using only 10w-30 or 10w-40 motor oil....
i have done some research.... and yes, these old units do use motor oil...
well i have been using hydraulic fluid, and so was the previous owner, but it has been working fine lifting and lowering the motor...
so my question is... should i start using motor oil? the unit was pretty contaminated with water from leaking threads, so im going to drain the whole system... and maybe now would be the time, if ever, to make the switch back to good old 10w-40....
or should i continue to use hydraulic fluid?
Thanks guys!
Thanks guys!
