power trim hoses
jopes
I got a hose that's starting to fray and I figure it is probably best to replace all 4 hoses rather than having them blow out on me. My issue is I can't figure out which ones I need from iboats. It is a 88 Maxim with a 5.0 alpha one drive.
MarkSee
Re: power trim hoses
These links may help you a bit as it seems you need to get the OEM part number then look on the IBOATS link and scroll to where you find that OEM part number.
By what I can tell for your model, the hose from the distribution block to the front (#3) of each ram is 32-99904q, the starboard back (#6) which shows 2 choices and port (#7) has 2 choices. Not quite sure of the differences with those 2 choices.
http://www.mercruiserparts.com/Show...=220&bdesc=TRIM+CYLINDERS+AND+HYDRAULIC+HOSES
Then looking at the IBOATS page: Mercruiser Power Trim Hoses - iboats
scroll down for either the Sierra or Mallory choices and there are some descriptions on what they fit and the OEM part number.
Mark
jopes
Thank you for posting that link. Don't know why I forgot about it because that is where I ordered all my swivel pin stuff from.
