Starcraft5834
Thread starter- Joined
- Jun 2, 2013
- 1,677
Pic of trim motor, pic of throttle,,, other day trim would not raise,, pushed button for trim or tilt raise,, clicking only, had to give the motor a whack and it started ok,,, that a selonoid issue? I found replacement seloniods for about $15 each,, there's two of em,,,one for tilt button and one for trim button... Checked it again this morning, the tilt works fine, trim button, only up is working, not down... This may be a dumb question,,why two buttons on the throttle lever when they both appear to perform the same function, raise and lower the drive..? The entire trim motor and unit is mounted on a base with three screws each side into floor, I assume all I need to do is unscrew those and pull the unit out to replace the seloniods?,, should I disconnect the trim lines? any http://forums.iboats.com/attachment.php?attachmentid=203952&d=1374246493&thumb=1&stc=1special procautions there? thankshttp://forums.iboats.com/attachment.php?attachmentid=203953&d=1374246511&thumb=1&stc=1
