For the second year in a row the power trim stopped working as the season ended.
The first year I noticed the fluid was milky. I drained, filled and cycled the trim a bunch of times. It fixed the issue for most of the following season (last year).
When I ended the season I repeated the same events as before with limited success. It would work once or twice and then the pump would get louder as the outdrive moved slower or stopped moving. I probably drained and filled the pump 10 times.
Now that I am getting ready to put the boat in the water, I want to fix it once and for all.
Is the fluid still contaminated or is the pump/seals worn? Can I disconnect the return line at the pump and drain all the fluid?
What steps should I take to trouble shoot?
It's a 98 Bayliner, with the 4.3 mercruiser. I used 30wt engine oil/
