88 OMC 4.3 I raised the outdrive with the trim button with no problem, and now when I press the trim button to try and lower it back down, I got nothing no juice...! Nothing out of the ordaniary happend (no noises, clicking or electric burnt smell)I have the key turned on (motor not running) and other accessories are working fine (bildge pump, blower etc). What are the chances that the trim switch (button) is no longer any good...? Are there any relays or fuses relatated to the trim switch that I can check for voltage...? If the switch is acually no good, where can I get on of those (it is part of the controls)...<br /><br />All responses are appreciated!
