power trim problem
bills231
i am having trouble with my power trim, my motor is a yamaha 175hp i have a 24 pitch 4 blade trophy prop,it is on a 21' bass boat, when i have the motor trimmed up and starting to take off the motor will drop all the way down, it has a new power trim motor on it could someone help me and tell me what could be the problem and how to fix it, thanks bill
86RajunCajun
Re: power trim problem
Check the manual relief valve, usually it is on the bottom side of the transom bracket. It has O rings on it that can fail causing the leak down.
Could also be internal check valve failing, or the seals inside the trim motor to housing.
GL
RC
