I have a 50hp Mercury OB with power trim. The power trim will trim the motor up with no problems, but when I push the button to go down the power trim does not go down. Once it started to go down then stopped. I put it in full trim to check the oil level and it seems to be full, oil comes out of the plug when I removed the plug. Power if fully charged, but does not react when switch is used on the motor housing or on the throttle. Not sure what to look a next or try next.
