You would have better anwsers if you started your own thread, that said look on the starboard mount bracket there is a 1" hole the release valve is the slotted screw thats in there. The o/rings on the valve commonly go bad, so remove the eclip that retains the valve and take it out and check for a bad o/ring.
Depending on the boat it's pretty much right at the water line.
