Power trim tilt unit
f1bigdaddy
Have a 1986 Yamaha 40Hp motor would like to add a trim tilt unit to it ,My question can a trim &tilt unit off a 90Hp Yamaha model FTLJ ser#458370(power trim Tilt model 5h0234)work on my 40Hp if not what would Thanks in advance for any help
angus63
Re: Power trim tilt unit
Pretty soon this post will be moved to the Yamaha forum. Click on Iboats boating forums above, then repair and maintenance, then Yamaha and post your questions there. Welcome to the forum and Good Luck.
Mod2
Moving to Yamaha/Suzuki forum.
Ray Neudecker
I know that you will have to change the complete bracket assembly to convert to tilt and trim. An aftermarket plate with it built in may be your best alternative.
mat191
Hello<br />I just did this job myself. I have a 86 50 etlj so it only had tilt. So after a week of e baying i got ahold of a 92 pro 50 midsection for $30 Only thing is i wished i got the C.d.i an timer base from him also. Do to the bigger TNT from the pro 50 it draws alot more juice an 86 50 charging system has a hard time keeping up.
