Power trim/tilt
tomatotom
I recently purchased a 96 Force, 40HP with power tilt/trim. I was concerned that it wouldn't climb over logs etc... when the need should arrise. In a seperate post, I was told there in deed was a built in relief valve, but was unable to activate it by lifting on the motor. Next, i purchased a Clymer manual and identified the location of the valve, which consists of a spring, needle valve, spool and another what appears to be plunger. I can't seem to get the plunger out of the bore and suspect thats why it won't pop off under pressure. Anyone out there been into these deep enough to confirm? Or any idea on how to get it out and at least inspect it?
RRitt
Re: Power trim/tilt
aw man, you really don't want to be messing with that. take it out one time. look at the nylon tip. it should be a ball. If it is twisted off then it is broken. If the ball shape is still there at the end then it is not broken. Put it back and leave it alone.
If your trim goes up and down then it is working. The system isn't meant for you to manually lift engine over logs. If you want to go through loggy swamps lifting motor up over every log then go with one of those vietnamese weed-whacker outboards.
