Power trim V150 mercury
stocky
Have not used the boat for about 18 months. This weekend gave her a check out and the power trim is not working. When I switch either up or down all I get is a click sound from down around the pump. Do you think that over time the pump has frozen or do you think there could be something else wrong. The engine is a 150 black max early 80's. Thank you all in advance.
Barnacle_Bill
Re: Power trim V150 mercury
Check all your connections and make sure they are clean and tight.
KCLOST
Was the motor stored for that period of time in the down position?<br /><br />Did you see any oil leaking from anywhere or on the ground before working on it? <br />It's possible it just is low or has leaked all fluid as the resevoir is under pressure while in the down position.
achris
More fish than mountain goat
Sounds like a siezed trim pump motor.
