Re: Power trim
On the advise from a friend in Alabama, I loosened the hydraulic line from the bottom of the tilt cylinder, removed the screw from the hydraulic reservoir, bled the line and let the motor come down to the trim cylinders. I then refilled the reservoirs with marble mystery oil, raised the motor up slightly and allowed to set. Every 2 hours, I would try to lower & raise the motor. After about 6 hours, the motor lowered completely and raised fine several times. I will now drain the mystery oil and refill with hydraulic fluid. Being new to this forum and a 1st time user, I thank all of you that responded. Maybe this will help someone else. Thanks- Thumper 48
