Power Trim
KYNC12345
I have a 2008 Yamaha 50TLR with a power trim that attempts to lift but doesn't. Battery is good, fluid level is good. Worked going on lake but not upon return. No visible leaks. Make a weak lifting sound like if battery was low, but again battery is good. Please help.
99yam40
hook a voltmeter to the incoming and out going terminals of the T&T repay to see what kind of voltage is getting to the T&T motor, would not hurt to check the voltage is on the battery itself to compare to that the T&T relay and motor is getting.
maybe just burnt contacts in the TT&T relay not letting full voltage to go to motor
boscoe99
Or disconnect the terminals from the relay. Apply battery power directly to the blue wire and the green wire. See if the T&T unit functions normally.
KYNC12345
Thank you very much for the information. I'll do that as well and I'll let you know how it goes.
KYNC12345
Thank you for that information. I'll check and let you know how it goes.
