Thought I had one but my 13 year old grandson just moved back south. dang it!
Sorry I couldn't resist. :embarassed: :facepalm: :lol:
Is he 12 volts?Thought I had one but my 13 year old grandson just moved back south. dang it!
airshot has the right idea only thing to think about is weather you have a 30 A fuse to connect to.
If you car has a 30 AMP fuse use it that is what they are made for. Otherwise yes your only other option is to run it to the battery.If you are going down the route of a plug in the back, it is best to run fairly heavy gauge wire directly to the battery and fuse it up there. I'd never try pulling a 30 amp feed off the existing vehicle fuse box, way too much to go wrong and $$$ to repair.
There are wire gauge calculators where you tell it the amps, and the distance, and it spits out the minimum wire size. (it will most likely be substantially larger than what seems to be needed, but voltage drop at 12v is pretty bad.)
Its just as I figured - even the small ones take too much power. This is just for a little fishing boat, to make things a little easier when I retreive alone on wavy days, using my daily driver SUV. Not worth the trouble to run wires.
If I get that old and feeble I'll just use my main towcar that is already hard wired for a Powerwinch.
Thanks to all for the comments...
You might not be young but you have more knowledge than us young ones that are still learning a lot.Jim, I can relate. As I've stated many times in this forum, I use an unimproved ramp that doesn't even have a pier. So yes when the wind get blowing it gets tuff sometimes. And I certainly am not getting any younger!!
