Powerhead identification 70hp evinrude
saltlifer
I recently purchased a 1995 evinrude 70hp two stroke outboard.the tag indicates that it is a 95,but a envinrude guru looked at it and said the powerhead was older than 95.what can i check ensure what year model of the powerhead.
sutor623
Re: Powerhead identification 70hp evinrude
What color is the paint of the powerhead?
saltlifer
Tpowerhead is black.the lower unit and midsection are the dark blue.
phillnjack2
Ensign
ive got 2x 1995 54ci engines both have black powerheads and dark blue casings.
mine are the 60hp variants but its just bigger carbs on the 70hp version,everything else the same.
on the cylinder head will be a core plug, just check the number of that.
also take a pic of the powerhead and post it here.
here is a few pics of mine to see if its the same. if it looks the same as this then its a 1995.
the water tell tale is on the top also the block looks like it is a sort of orange peel effect.
the cylinder head where the thermostat housing is a different shape to older syle as well.
what year does your omc mechanic think it is ?
phillnjack2
Ensign
also the hood is different to previous years and the mid section and leg dont have coloured stripes !!!!!
this pic below is what the 1995 model evinrude 3cyl 50 , 60 and 70hp engine looks like
saltlifer
The plug on top is am-70a g175788 i havent figured out how tto open the attachment that you sent me.
saltlifer
Also the tag says its an e70tleor.
