powerhead question
chrisn
Just purchased a rebuilt powerhead for a 1974 70 H/P Evinrude outboard. My problem is the choke thermal switch that normaly is located in the head is unable to be reinstalled. (no hole) The waterjacket does has a 1/8th npt hole that my old powerhead didn't have, does anyone know if this is an upgraded for the switch and where I might find one? Am new to outboard motors and would appriciate any help
Joe Reeves
Re: powerhead question
Avoid reinstalling that thermo activated choke setup as it was a first class OMC boo boo. See the following.
(Temperature Actuated Choke Solenoid Conversion)
(J. Reeves)
Various OMC engines that were manufactured in the later 1960s thru the early 1970s, for example the 1969 55hp Evinrude/Johnson incorporated a dual stage choke solenoid...... easy to identify as they have two wires leading to the solenoid, one purple/white, one purple/yellow.
The purple/yellow is attached at the engine wiring terminal strip to another purple/yellow wire that led to a heat sensor. The initial stage, with the key ON, (purple/yellow), when cold, would keep the choke pulled in half way until the engine warmed up, at which time it would release and open the choke butterfly.
The second stage (purple/white) is attached to another purple/white wire at the engine terminal strip which leads to the choke switch. When the switch was engaged, the choke closed etc.
The problem with this setup is that as the engine got older, the thermostat acted up, water pump became weak, whatever, the heat sensor failed to operate properly and the choke would not release from that half closed position. This would cause the engine to run in a rich fuel mixture condition (flooding, loading up).
The cure to this problem, via a service bulletin from OMC was to remove the solenoid purple/yellow wire from its original location and connect both of the solenoid wires (purple/yellow & purple/white) to the engine wiring harness purple/white wire at the engine terminal strip.
The above change would allow both solenoid wires to be energized when the choke switch is engaged, pulling the choke butterfly in firmly..... and only when the choke switch is engaged.
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
chrisn
Thanks for your response,I can't reinstall this switch (the hole isn't there in this rebuilt powerhead) unless there is some other place for me to install it on the engine block side.so will I just connect the other side of the purple/yellow and purple/white wires together at the terminal board?
