Harv maloy
Thread starter- Joined
- Oct 12, 2016
- 5
Hello I am new to the boating world. Especially the rebuilding boat world. As such I have jumped in head first with a 1968 falcon restore. The boat came with a johnson seahorse 40 hp motor model rkl-30-c that had electric issues. I replaced coils condensers n points and sent the generator and voltage regulator off to be rebuilt. While they were gone I took a chance to test run the motor in the lake it ran well for about an hour. I shut it down to drift for a bit n when I went to start it back up it sheared the key in the fly wheel and long story short tore itself to shreds.
Thas the story that leads us to this post. After destroying the johnson 68 powerhead I found a 62 evenrude lark 4 outboard with a good powerhead. the lower is a long shaft and pretty blown in the evenrude. The lower in the 68 johnson is totally rebuilt and clean. The blocks are the same I have already pulled the powerheads and bolted the evenrude block to the johnson frame it dropped right in without a problem.
The problem I am facing and am hoping to get some help with is wiring. I have very little motor expirience and even less when it comes to wiring plus these are the first outboards I have ever worked on. I have wiring diagrams for bouth motors but they don't explain where everything is located on the motors. The main problem I am having is identifying cretin parts like which is the cut out switch, and which is the kill switch. But mainly what is getting me lost is in bouth diagrams there appears to be 2 buss bars where a lot of wires tie in together and switch colors. Unfortunately I cannot locate these buss bars on iether motor or how these wires are supposed to come together. Also the starter soliniod for the 68 johnson is locate in the frame for the exhaust housing, on the evenrude it hase to be located on the motor because there are no electrical components in the housing for the evenrude. And I can't find the starter solenoid on the evenrude.
I'm sure the info I have left is pretty vague if there is any more info needed please let me know. I can also post pics
