powerhead swap
chavonbravo
hey all, i'm just wondering if an '79 johnson 175hp powerhead would be able to be switched for an '88 johnson 175hp. thanx.
Joe Reeves
Re: powerhead swap
No, it will not interchange. The exhaust setup is different.<br /><br />This is easily recognized as per the 1979 175hp has a flat exhaust baffle plate, whereas the 1988 175hp has the extended (bubble) type exhaust baffle plate (same as the old 235hp models).
jy118lfd
Re: powerhead swap
If they are both crossflows You can change it but you must change the adapter plate and inner exhaust housing
