Powerhead to midsection bolts. HT required?
Bosunsmate
Hi, im replacing powerhead bolts that bolt the powerhead to the exhaust/middle section.
These bolts on outboards ive worked on often seem to seize due to their positioning in the salt spray zone. Ive twisted the head off some of these bolts before which were done up for over a decade. Getting them out after that really is not great times.
Should i put in stainless steel high tensile or is just stainless ok? I intend to coat them in permatex aviation form a gasket and back them out every couple of years.
Thanks
Chris1956
Re: Powerhead to midsection bolts. HT required?
Normally Mercs have stainless steel fine thread studs holding the powerhead to the midsection. You should see about 6 - 8 nuts holding the powerhead to the midsection. What motor do you have?
Bosunsmate
Hi, just quietly its a johns...on but i much prefer the answers from here. I suppose the nuts are they high tensile? I broke a few off my merc500 in the past
James R
Go get some OMC gasket sealer, the brown sticky stuff. I use this on all my bolts and it works, salt water as well. Most bolts I remove, other than those needing thread locker, get the OMC sealer.
Bosunsmate
thanks, i will look that product out. A cold chisel should go no-where near this engine again
