Pre 1997 Honda BF75 Oil Pressure Light
w2much
Light is very dull, really have to look at it shaded to see that it is on. Does the bulb go bad? Or the oil pressure sender? Motor runs great.
boobie
Check for any corrosion in the wiring or the bulb socket it self.
w2much
Not certain yet. Did find a corroded wire on the lamp itself which promptly broke off when I tried to examine it. Will have to replace. Not certain that it was the whole issue. May be a bit but I will post when I find the issue and the fix.
w2much
Very good. That will work as for the lamp replacement. Thank you for the link and your reply.
