Pre Alpha 1 228 lower unit install
Deep waters
My ignorance is not bliss. I did not put the drive in forward before removing the lower unit. As a result the prop shaft will not engage and I can't align the outdrive shaft to engage.
alldodge
Welcome
If you just dropped the lower half of the drive, then no issue
Move throttle to forward
Rotate shift shaft until the prop locks in Reverse (note Rev not Fwd)
Raise the lower half into upper half
Deep waters
Thank you. I can't get the last 1/4" to marry. Also, while shaking it around to fit, the shift shaft is no longer in reverse. Your thoughts please?
alldodge
The shift foot should be point forward on the upper half and should be held in position mated to the shift shaft on the bell housing
The prop isn't staying lock in rev so the shift shaft is moving. Could put it in position and then use a bungee cord on the prop to keep the prop locked in place
The splines on the lower shift shaft will mate with the upper shift foot, and it might hang on the 2 pieces if they don't align correctly. It can be done but sometimes it just not worth the trouble for me to save the gasket on the upper.
The easiest way I've found to do it is pull the upper, mate the lower with upper and than install drive
Bt Doctur
All Dodge, I think you meant shifting into full fwd at the control box and rotating the lower splined shaft fully clockwise into fwd ,that will lock the prop in a CCW position not reverse
alldodge
I said it the way I did so I didn't need to explain anything about how the dog clutch works
Deep waters
Thank you for the good information. The shift shaft coupler is pointing port. I positioned the shift shaft to match. Does locking the prop in reverse still apply?
alldodge
Shift shaft should point straight forward not to port
If the lower is in forward the prop will lock when prop is rotated counter clockwise
Deep waters
All is well for now. I haven't yet checked the shifting as I need someone at the throttle to help. In the mean time, now that lower and upper are mated, I need to remove and reinstall it. The bolt to hold the zinc fin fell out and rolled under my work bench. It's a good day! I get to practice.
Deep waters
Specifically rust and oil. 1975 Mercruiser Alpha MC1. If you can point me in the right direction I'd appreciate your insight.
