Well that didn't work - I need a exploded view of the bearings inside the gear assembly ,there are 3 ,one tiny one med. & one large ,help....Mercruiser sterndrive 120hp pre alphia old style pump.thanks
Re: pre alphia sterndrive mercruiser tilt & trim valve body
You are not being clear with what you are asking. Use service manual #2 which includes repair and diag of the trim/tilt pump. To my knowledge the top motor cap and commutator plate is the only thing serviceble. If you end up getting into the pump housing, you my consider replacement.
I need a link to the service manual 2 if possible, thanks ..Its the gear assembly diagram I need for a 67. Took it all apart & cleaned old oil & sludge. I have another same style maybe a little newer that I just removed the reservoir from the gear & valve assembly only & cleaned put it back together & running the pump motor out of the boat in a container still had sludge & was only spitting air & milky oil in the up,nothing from the down while electric motor functioning properly.
So it has to be inside the gear & valve assy. Right?
I believe the one that is apart would work if reassembled correctly. Tiny check ball seems to be in place now I have 2 check balls left which I believe rests on springs one large & one a little smaller.
I have about a 50-50 chance on getting the check balls right the first time almost guaranteed the 2nd.lol Thanks again !
The link for #2 is there. That valve body was rendered NON-servicable by prestolite when they started using it. The manual has nothing but a view of fasteners. Then reassembly of different components.
I appreciate the help obtained here! Took Pete's advice & purchased a used valve body & gear assembly & pumps pumping as it should.
I will now address the reason I believe the water got into the pump in the first place .
I suspect the trim arms ,one or both possibly leaking its the only way I can see it happening.
Trying to avoid a short life for this fix.
