- Joined
- Jul 18, 2011
- 19,649
Not sure if I will start a Holy war by asking this, but . . .
I am wondering what the consensus is regarding the way to perform a cylinder leak test?
It seems, by checking various publications and forums, that the popular way is to have the cylinder at TDC (top dead center) on the compression stroke.( i.e at the end of the compression stoke)
There are some who profess BDC (bottom dead center) - could be either compression of exhaust stroke. The only thing is that you have to back off the rocker arms with this method as the valve(s) is/are still open at BDC, due to 'overlap' designed into most engines. The BDC is said to be 'safer' since the piston will say at BDC.
The TDC approach runs the risk of the piston turning the engine violently.
I prefer the TDC method since it also checks the condition of valve adjustment. It just requires more precise positioning of the piston at TDC. If you do the BDC approach, then you have to perform a valve adjustment after the leak test is done.
What do others have to say?
