boater1234
Master Chief Petty Officer
Thread starter- Joined
- Jan 6, 2010
- 869
Hey guys i need help on a small subject.I am painting my outboard and have all the knowledge to paint it right from the people here.I am stuck however on one small thing.I have heard some people use alumiprep and alodine.I have also been told to use 50/50 water and vinegar before putting on the zc primer.I can't seem to find any of the 2 chemicals anywere here in my local area of port richey,fl.I have hit hardware stores and a ton of marinas and even some paint stores with no luck.
Now doesn't the 50/50 water and vinegar do the same job as the other 2 chemicals?Do i need those chemicals for my paint to stick or will the water and vinegar be enough?Also is there another chemical similar to the alumiprep and alodine i could use.Like i found a naval jelly that is made specifically for aluminum in ace hardware,it says you can use that to clean the bare aluminum off before you paint.Will something like this work?I read the alumiprep is like an acid for cleaning so i would think the naval jelly or water and vinegar would do the same.
I just want to make sure the zc primer will stick as good as possible to the metal.Thanks for any help.
