Jgranger01
Thread starter- Joined
- Apr 27, 2022
- 20
Before setting the preload on the yoke bearings do you have to push the bearings off of the pinion gear if you are not replacing the bearings?
What is the preload now and why do feel the need to adjust it?
You don't have to remove them but you do need to 'loosen' them. Only needs them to move a few thou apart....Before setting the preload on the yoke bearings do you have to push the bearings off of the pinion gear if you are not replacing the bearings?
You don't need to disassemble the bearing pack completely, as stated you do need to "release" the current torqued state of the bearing set and upon reassembly use a dial lb/in torque wrench to set the preload to 3-7 lb/in.I just didn’t know if the prior preload needed released by removing the bearing and reassembling or if I could just replace the seal and then torque in back down with a new washer?
If you hold the bearing pack in one hand and tap the back side of the gear with a hammer that should be enough to relieve the bearing set and have a loose starting point for reassembly. The process is outlined completely in the oem service manual. #6 for alpha one #14 for gen 2
Chris,You don't have to remove them but you do need to 'loosen' them. Only needs them to move a few thou apart....
Chris..
Could I get away with using the 0-150 in lb one? because it’s significantly cheaper. I realize it’s an inferior tool but it seems like it should get the job done.Seekonk also make 0-30 in-lb
Seekonk TSQ-30 1/4" Dr. Rigid Frame Dial Type Torque Wrench 0-30 in.lbs.
<p>The Seekonk TSQ-30 1/4" Dr. Rigid Frame Dial Type Torque Wrench 0-30 in.lbs. has become the standard by which the competition is judged. Unique durability is built into tools shaped from chrome plated high alloy steel. These tools feature a torsional bar system manufactured from a special...www.seekonk.com
If you can differentiate between 5in-lb and 10in-lb, and it's calibration is good right down to the bottom, and you're confident in it, yeah sure...Could I get away with using the 0-150 in lb one? because it’s significantly cheaper. I realize it’s an inferior tool but it seems like it should get the job done.
You can do what you like but that wrench most likely will not read accurately enough for the 3-7 lb/in rolling torque requiredCould I get away with using the 0-150 in lb one?
Thanks for the input guys. Always appreciated. I’m gonna try that 150 in/lb one and if doesn’t work it’s from Amazon I can just send it back and I will take it to the local boat shop and pay them to torque it.You can do what you like but that wrench most likely will not read accurately enough for the 3-7 lb/in rolling torque required
Problem is you won't know if you have a problem until you explode your drive. Wonder how accurate a small scale beam unit would beThanks for the input guys. Always appreciated. I’m gonna try that cheap one and if doesn’t work it’s from Amazon I can just send it back and I will take it to the local boat shop and pay them to torque it.
