Ok i have a 1991 Alpha1 GenII 3.0L.....I few weeks a ago i took off my out drive for the winter and i was going to check the gear oil and water came out for a good 10 seconds then the gear oil which was green....i just got my home made pressure tester and tested the lower unit without the upper and put in about 15psi and it held for a good 10min i can see fine really fine air bubbles coming from the shaft seal after spraying soapy water.....So my question is....could this much water enter the lower unit from the shaft seal as the water pump is turning?
it doesn't make sense....
