Pressure Tester
joe Hetz
Where can I get a pressure tester for my lower unit? It is a 94 Mercury 75 H.P. <br /><br />Thanks in advance!!!!!!!!!
NathanY
Re: Pressure Tester
You might be able to rent one at your local parts store. I rented a vacuum tester at Oreilly's for 6 bux, and it worked good for testing my lower unit.
Yepblaze
Re: Pressure Tester
I tore the valve stem off an old bike tube and grund the rubber end to a sligt taper that will screw in the plug hole quite well. Then use the bike pump with the guage on it. Worked pretty well.<br /><br />But if ya want the real stuff try http://www.stevensinstrument.com/
Trent
Re: Pressure Tester
You can go to Sears or NAPA autoparts and get this Mityvac which works well. Will do pressure and vacuum.<br /><br />
joe Hetz
Re: Pressure Tester
Thanks for all the good advice. I knew I could count on you guys!!!!!!!!!!!!!
