Pressure testing sterndrive
Dui
Alpha 1 gen 2 sterndrive. Can someone confirm that pressuring through the vent hole after draining the oil one must pinch the fluid hose at the reservoir to allow pressure to hold. The only procedure I found is for general 1 which does not have reservoir. Any procedure available for gen 2 with reservoir? Thx.
achris
More fish than mountain goat
Re: Pressure testing sterndrive
You need to remove the drive from the transom first, drain the oil, then connect the pressure/vac gauge and test it....
Chris......
