Ayuh.......<br />Either the Vent, or Fill screw will work........<br /><br />BTW, It's a 3/8ths X 16tpi.......<br />Either robbing the connector off your oil fill,<br />Or drill a hole through a 3/8ths X 16tpi(standard 3/8s Course Thread) bolt.......I assume you can pressurise and also do the vacuum test at the same place, i.e the vent screw on the side of an Alpha Gen II
