Re: Pressure Treated or Not??
Hi Bill!
Don't waste your time talking to Craig. There are dozens and dozens of threads where people say to use pressure treated ply for the deck, but Craig never jumps on them. He just has a hair up his butt because I link the documents that prove its is a preferred material in boat building.
BTW, I really don't recall recommending Home Depot lumber as the primary source. I always recommend going to a "lumber yard". I may have mentioned HD at some time, but Craig just loves to twist around what you post to make himself look good. Also note that he has a propensity for name calling and derision. Two traits that are common to bullies and those in the wrong.
So don't bother with Craig. Do like I do and just laugh at him. He's a good joke.
Okies... this sounds like half a PM and half post ( I do this all the time
Lets just Chillax as Christmas is here..
I Dont think Anyone ( excluding me
) should be laughed at m8s.. Craig is just another contrubutor to the forum.. and should not be held in contempt...
Personally.. I agree with Craig and his "Extream differences" .. ( he may not know the in and outs..and maybee he does.. I dunno ) .
I have been kinda .. erm.. lean on the topic..
You can use PT..
You can use cdx..
you can use bc..
you can use whatever you want..but if your asking ..then use the Right STUFF.. ( Anyone here wants to say that DF MG grade ply IS NOT the BEST for your TRANS or STRINGERS speak up please.. ) ..
Yes .. you can use cd..bc..ab..whatever ply you want if you Think its in your Price range !.. your going to use More resin and time to make your ( Insert trans or stringer replacement here ) replacements without using MG ply...PERIOD ! .. ( Unless your getting some crap ply that will WARP as soon as you cut it .. ).
No need for the Science...just Know what your using..and how to use it.
I personally..again..use ONLY MG doug fur .. it does not warp as much when cut..and its everything as much as everything .. no questions asked ( unless I dont seal it right ) ..
Tabbing your trans is MUCH more important then what "filler/wood/etc" your trans is made of.. .. MAT will not cut it when tabbin your trans...
Too much involved in the core..and not enough in the Tabbing IMO..
Peace out..YD.
