Bt Doctur
Thread starter- Joined
- Aug 29, 2004
- 19,557
For those impossible to find deck drains use a thru hull fitting shaved down to fit. Most will simply screw into the OEM threaded fitting.
If you cut off the hose area. The Wellcraft 28 coastal uses these for deck drains and fish box drains. Chucked in a lathe to skin it and reduce the diameter and your good to go.
