Lucrestyle
- Joined
- May 25, 2007
- 98
When priming the ball on my 1993 rude 120, the ball will get hard and then a couple sqeezes later it will go soft again? what would cause this?
Good idea.Insure that the fuel tank vent is clear and venting as well.I should mention that this problem started to happen only after i disconnected the hose to run seafoam through the engine from an aux tank. I guess I will try reconnecting the hoses to rule out any air leaks.
Exactly why are you concerned about this? Consider what is going on inside that bulb: When you squeeze it, you are pumping gas to the the carburetors. Once the carburetor bowls are full, the float valves shut off the flow from the primer bulb. That is when it gets firm, because there is nowhere for the fuel to go.
Then, since the carbs are full you can start the motor. From that time on, the fuel pump on the motor starts sucking gas from the tank. Since there is now a suction condition inside the squeeze bulb, it will no longer be hard. However, trying to override the fuel pump by squeezing the bulb will momemtarilly make it hard again, but only till conditions change from pressure to suction as the motor runs and consumes the fuel from the carbs.
Is this what is going on with your motor or are you telling us something different is happening?
bad check value in the bulb. or the needle float values in the carb are stuck, and the pressure is opening them, letting gas in. goes it get hard again after doing this.. if not check valve. replace the bulb.
