Primer bulb does not achieve hardness
daschtick
I have a Force 120 with a problem - BIG SUPRISE! I have the classic 'running out of fuel' symptom that everyone else seems to have after running above 2500 RPM for 1-2 minutes. I can fix it by re-priming the bulb, but it can happen again, unpredictably.<br /><br />Also, when priming, I have noticed that the bulb never achieves full hardness like it used to - or at least I thought it used to. So, I changed the bulb, but that has not fixed it, and no gas appears to be leaking anywhere in or out of the motor. The bulb is installed correctly, and I have noticed that if I clamp the fuel line after the bulb, i.e motor side, I can get it to get hard.<br /><br />Whaddya think?<br /><br />-Nick
MGuckin
Re: Primer bulb does not achieve hardness
If you can achieve a hard bulb by clamping off after the bulb, you must have a leak in a line or seal somewhere. Fuel line is cheap, about a buck a foot. Change it all, won't hurt. Might have a carb gasket leak, carb diagraphm or pump problem but you got to start somewhere.
MURX
Well at least you won't have to buy Viagra..... or worry about the wife leaving you over a bulge that won't achieve "hardness" :rolleyes:
crab bait
GOSH DARN IT MURX.. YOU BEAT ME TO IT !!
sony2001
There is easily available a kit to rebuild your gas pump for $5.00 to $10.00. Go for it!
