Primer bulb going flat
cookbayou
Ive got a 1997 75hp force. The primer bulb started going flat when the motor is running. Whats up with that?
pnwboat
Re: Primer bulb going flat
Means that the fuel pump is pumping fuel faster than the gas tank can supply. May be a bad primer bulb, blockage in the fuel line between the bulb and tank, or something in the tank blocking the fuel pick-up.
tds1774
I had same problem, after alot of frustration I tracked it to my 6 gal tank, the hose inside the tank was getting sucked flat replaced the hose / filter not happened since. btw my primer bulb is origional at least looks that way still works fine, I would save the bulb for later in the troubleshooting process
