Snowfish
Thread starter- Joined
- Jul 3, 2009
- 234
96 Merc 60hp 3 cylinder. Primer bulb not pumping, so I replaced it. Still the same. It's not filling the carbs with fuel. Pulled the carb plugs to check....nothing. Engine will start, but sometimes pretty difficult. Even after it starts, and runs good, it will bog out, die on occasion, or just pick up and run great. When it dies, I play with the primer, choke, fast idle, etc and it will start. Let idle, and feather the throttle and we're back in business. Then it will run like a champ for a long time. Maybe even the rest of the outting.
Impulse line appears OK. New fuel filter last season.
Is there a check valve in the fuel pump? Or is the pump just ready to be replaced? Open for ideas.
Past seasons I've only had to use the primer bulb at the start of the season. Then just choke a little, and we're good to go after that.
