Primer bulb or no primer bulb on EFI's
Bugsy's Baits
Has anyone found that there boat was rigged with primer bulb for their EFI motors and didn't need the primer bulbs??????
My boat has twin 1999 225 EFI Merc Bluewaters and boat was rigged with primer bulbs......to be or not to be!!!!!!
Bugsy
daveswaves
Ensign
Re: Primer bulb or no primer bulb on EFI's
Leave em in, If you ever run out of fuel the electric pumps do not pull the fuel from the tank very well, they dont pump air. The bulbs can be used to get the fuel to the engine.
Sandjob
Efi's have a mechanical pump and won't pull much fuel on start up. If you have anti syphons I suppose you could run without them. If the motor sits for extended periods I wouldn't suggest it.
