have an early 80 pro150v. the oil pump was not working. Then when I turned on light switch it started pumping and would not stop. Overflowing. Fixed the light issue. Now when I turn the key to on, it starts hmmmmiinnnggg-pumping and won't stop. Overflowing. And is the cap on oil tank suppose to come off so easy.<br /><br />Is there a fuse or ground somewhere. Or is this just the sensor in oil tank gone bad. Old owner says boat always made noise when key was turned on but it would stop.<br /><br />I have no clue. Just got the boat. It ran two weeks ago without any problems.<br /><br />thanks for any and all help.
