Fastertelecaster615
- Joined
- Jul 7, 2016
- 1
Hey folks
I am totally new to boating, however, I have rebuilt 4-stroke vintage Honda motorcycle engines, so I am not afraid to dive into a marine engine.
I got a 1974 Fabuglas Fishing Boat (14.6") with a '74 Merc 850. I got it with a BMC trailer for a song, so I am ok if someone says "send it to the dump and start over"
It was advertised as needing a new wiring harness. There were two automotive type cables coming out of the cowl hole (lower right) that went to the starter, and the starter solenoid. It appears complete (nothing seems to be missing). The starter motor worked so I thought I would test her.
I rotated the prop and all seems well. I pulled the plugs and did a compression check on each cyl and got 135/140/135/125 (1,2,3,4)
I downloaded a manual from recrepair.com but it is a generic "how to service 1965-1989 Mercury Outboards"
There are lots of specs in the appendix except for expected compression. Anyone have this figure?
I suspect I may have sticky rings in cyl 4 but maybe all are bad if compression should be 160+.
Looking for a definite answer on the spec compression figure. Thanks!
