rhillman75
- Joined
- Jul 28, 2010
- 176
I have a 1999 Mariner 40HP Jet 30 3 cylinder 2 stroke. My question is is that the service manual calls for the intial setting from factory is 1-1/8 from seat. So I did this on all three carbs. I have them all in sync, timing is 2 degrees after TDC, and spark advance is 24 degrees after TDC. My question is how do you go about adjusting the 3 carbs at the same time. Do you master one then go to the next? I can't seem to get a completely smooth idle from the motor with all 3 carbs adjusted the same. Floats, filter, plugs, 92 octane gas, seafoam, carb rebuild, fuel pump rebuild. It still runs the same...I am seriously think I just can't adjust these without some help knowledge. The local marina wants $135.00 (minimum charge) to turn 3 screws and probably about 10 minutes worth of work.
