Problem going from reverse to neutral
jscott84
I have a 93 Bayliner Capri Mercruiser Alpha One 3.0L. Boat shifts from forward to neutral with no problem but when i'm in reverse and go to neutral, it doesn't kick out of reverse. I have to go to forward and then back to neutral to kick it out of reverse. Simple fix or no? Thanks!
Re: Problem going from reverse to neutral
Ayuh,.... Either the interupter switch, or the lower shift cable is Failing...
My guess is the cable is causing the issue...
