Re: Problem starting warm motor
I am having trouble restarting my 75 horse Mariner once I have run it for a while. The first start of the day is always the easiest. After that I have to crank it several times and wait between tries. When it finally starts there is alot of smoke but it goes away and the motor runs great. This is only my second time out with the boat. What is the best method for restarting the motor without flooding it. Please help!!
ok, i'll give it a shot. i'm a plumber so get your grain of salt handy. first, try to solve the problem. carry a spare spark plug. when the motor is warm and not wanting to start, pull off a plug wire, insert the spare plug into the wire hold it to ground and have somebody crank it over. if you have a good spark try other cyl(s) to make sure your ignition system is working. if you crank the engine alot without spark it can flood it even if you dont have a fuel problem. if spark checks out ok the the fuel system is probably to blame. could be a few different things. float level may be too high, fuel pump diaphram may be leaking. warm/cold starting problems can be a pain to solve. try to eliminate one possibility at a time. good luck
