Re: problem with 175 Johnson!
Relays are like single pole, double throw switches. When you apply power to the relay primary, it switches to allow battery voltage to pass thru it. When the relay is at rest, ground passes thru it.
You should have some small resistance across the primary. When power is applied, the relay should click.
