Ok,
So I have been having issues with my engine overheating and I redid the water pump again. I got it all put back together with new seals and all.
The engine still got up to 175. The engine is a 94 Mercruiser 305 with an Alpha 1 Gen 2 drive. The thermostat is brand new, and I tested it in a pot of hot water and it opened at the right temp. The thermostat is a Stainless steel Quicksilver brand with a temp of 140. I got this directly from the Dealer.
Before my engine would always run right at 165 on the high side. The impeller was not bad, and did not have any broken off pieces.
Here is what I am running into. I have thru hull exhaust with no Exhaust or any way for the exhaust or water to go through the Prop shaft. What I just found after putting the lower unit back on and everything being right and triple checking it. There is water leaking somewhere, as it is coming out the prop shaft. So it has to be leaking from somewhere around the water pump.
Here is what I replaced:
1) Water Pump Housing
2) Impeller
3) Gasket on the bottom of the Metal Plate under Water Pump Housing
4) Metal Plate below Housing
5) Gasket between Metal housing and Metal Plate
6) Face Seal on top of Water Pump Housing
7) Water tube plastic fittings and new o-rings for Housing side of Water tube
8)Rubber Filler Plug as described below and installed with the gap under the Water pump drain hole. The rounded lip sticks up making a open space under the drain hole
9) I tightened all the bolts tight, I do not have a torque wrench. Could this have caused the problem? Can you tighten them TOO tight?
Here is a picture of how I put the Rubber dam in.
Here is a picture of ALL of the Parts that I replaced with NEW Parts:
I put Perfect Seal below the (A)Gasket below and on the bottom of (B) the metal Plate, as stated in the Mercruiser Manual, here.
Please tell me what you think is the problem. I really do not want to have to do this more than one more time.
Bryan
2) Impeller
Bryan
