Problem with idle-1989 9.9 evenrude!
drillbits
Got an idle problem with my 9.9 Evenrude. Started out with a carb problem and re-built it and it ran fine, A few days later had a hard time starting and setting the idle. Pulled the plugs and noticed they were wet. Changed plugs and it ran fine until I tried to re-start again. Same problem-wet plugs! After getting it started again it runs good at high speed but still has a problem with the idle and the plugs still get wet. Anybody have a solution before I turn it into an anchor?
Bosunsmate
Re: Problem with idle-1989 9.9 evenrude!
Try resetting your float to close a bit earlier.
kbait
And replace the 5/32" fuel line from pump to carb.. if it's original, ethanol may have degraded the insides, sending crap into your nice clean carb..
