Problem with initial start 89 Johnson 110
wan2live
1989 Johnson 110
When I start it cold it take a few tries and if I let it sit at idle it will stall then I have to start it again.
After being on the water and sitting with it off for a 1/2 hour or longer I have to give some throttle to it to keep it going like it is not getting wnough fuel. What adjustment should be made to correct this type of problem?
the RPM's were to high 1500 so I adjusted the RPM down to 650 but I still had this challenge before that. The timing is dead on and the plugs are new, running 89 octane and correct oil mixture.
HighTrim
Re: Problem with initial start 89 Johnson 110
If you pump your bulb does it pick up?? Have you performed a spark test?
wan2live
Yes I need to pump the bulb for the initial cold start.
I have not done a spark test, is this just like a car? remove plug attach it to wire turn er over a little and test spark?
Also if I tilt my motor too far up she will stall at idle even while the bottom end is in deep enough.
HighTrim
Sorry i meant when its stalling, or bogging, if you pump the bulb will the motor pick up a bit, if so look to your fuel system, the pump especially. Directions for a spark/ compression test below. All you need is a cheap 20 dollar screw in type compression tester and a 20 dollar spark tester, or you can make one out of a board and nails.
(Compression & Spark Test)
(J. Reeves)
1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.
2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems.... and also the Battery Capacitance Ignition system OMC engines from 1968 to 1972, set the gap to 1/4". On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!
If there was no spark, on engines from 1973 up, disconnect the RED main electrical plug at the engine. Remove the s/plugs. crank the engine via the starter solenoid (jumper bat term to small 3/8" term nut, not the ground nut) and observe spark. If spark is now okay as stated above, the usual cause is a shorted ignition switch.
If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to one or both of two things. The carburetors are fouled, in which case the cure would be to remove, clean, and rebuild them..... or the timer base under the flywheel is sticking which would result in a retarded spark. If the engine will not fire/start at all even though you have the proper spark and compression, it's usually due to fouled carburetors.
To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem.
Usually any sticking of the timer base is caused by one of the four retaining clamps being slightly too tight. Putting a very thin washer under the clamp cures that problem. Some boaters use a thin screwdriver to bend the clamp upwards slightly but I prefer the thin washer. The sticking can also be caused by having a faulty stator start to melt down, resulting in a sticky substance dripping down on the timer base nylon retaining ring.
wan2live
Ok thanks for the info I will check both and report back.
