DagoExpress
Thread starter- Joined
- Jun 22, 2009
- 10
Hello,
I am having a problem with figuring out the proper pitch and prop size for my boat to get it on plane quicker. I purchased a 1984 23 ft. 5000 Century Sun Express Cabin Cruiser in Feb. of this year. It has a Mercruiser 228 305 w/ 4bbl carb (non vortec) with a Alpha one outdrive. The alum. prop that was on the boat when I purchased it had a piece of one blade missing (prop says Mich. smc 376 cup) I was told that this transfers to a 15 3/4 X 17 which I cant find, correct or not? I do not know if this is even the original prop for the boat. The owner gave me a new prop in the box which is a Turning Point Hustler 14 1/4 X 17 cupped. He said it was the correct replacement (NO WAY). I took boat out with new prop on and the bow rides high and takes a very long time to plane out even with trim tabs down at 6000 RPMs with 1/2 tank of gas (35 gal./74 max.). A friend gave me a prop to replace the new one which is a 15 1/4 X 15 pitch (no cup and similar to old one elephant ear style) and it is the same problem. It still only planes out at high RPMs. IM NOT LOOKING FOR SPEED but top speed is between 32 & 34 MPH @ 6000 RPMs. and planed out. I know i shouldnt run it that hard but in order to plane out I do. When cleaning the boat in Feb. I found 5 sand bags up in the bow where the anchor rope stores. Was he compensating for improper pitch? Im not looking for speed, I just want it to plane properly. I dont store water in the holding tank (plastic) nor do I have any unnecessary weight on board (unless you include the wife) only overnight cloths and a cooler. It does not have ANY water inside. Could you PLEASE help me figure this problem out because I dont need a garage full of unwanted props! Thank You Much, DagoExpress.
