problems after planing
siccmade
I have a 1964 18ft lyman with an 85hp evinrude motor. it planes out then at 4000 to 4800 rmps the boat tilts and the rear cuts hard like it trying to spin out or like I cut the wheel hard but it doesnt do it below 4000 rpms. please help.
kenmyfam
Re: problems after planing
Should put this in a section where it will get the information you need. PM a mod to move it or hope they see it and do the same.
180shabah
Is the skeg straight?
Do you have a hydrofoil?
what is the motor height?
siccmade
sorry new here I'm not sure where I should put it could you help
180shabah
Agreed - it's not an engine issue, not a prop issue, not electronic, fishing or destination related....
What is wrong with the general boating issues forum?
bomar76
One hell of a hook in the hull.....
CATransplant
Or one heck of a weight imbalance to one side. Sounds to me like the less of the hull that's in the water, the bigger the problem. Way too much weight on one side and she get's tippy.
A photo would be good.
siccmade
well the bottom is plywood and flat, weight is even, but the boat tip still and cuts hard I took it out today and tried sitting on the other side and it cut the other way would trim tabs help or a hydafoil.
Bart Sr.
Sounds like you are overpowered.The high speed is taking away your control.
Just thinking out loud.
JimS123
Your boat was designed by naval architects and built in a time when boats were boats. Hydrafoils and trim tabs are for the boats they make today and are often needed to correct basic deficiencies in the design. Your boat / motor combination should run perfect without them and adding them will not help you.
I would suspect that the hull has a rocker. If it had a hook it would probably just porpoise. In either case, though, the whole hull is probably hogged due to dry rot and / or improper placement on the trailler. It may look "flat", but to truly evaluate it you need to look very close.
Put a long straight edge down the keel. Raise the motor to get clearance, then look down the keel and check for symmetry on both sides of the keel. Repeat by looking from the stem. Lastly, check that the engine is centered on the transom and perpendicular to the bottom.
Finally, if you have cable-pulley steering, check to be sure the cable is tight. Both sides should have a spring at the end of the cable, and it should have tension on it. If either end is loose, the engine torque is turning the motor by itself.
180shabah
Or one heck of a weight imbalance to one side. Sounds to me like the less of the hull that's in the water, the bigger the problem. Way too much weight on one side and she get's tippy...
...I took it out today and tried sitting on the other side and it cut the other way would trim tabs help or a hydafoil.
I think we identified something here, and a hydrofoil will only make it worse.
