Re: Problems caused by ,motor being propped wrong?
Yes, first off it needs to be determined if the low rpm is due to one or more plugs not firing, carbs, poor compression on one or more cylinders, etc. IF the engine is in otherwise sound condition, lugging it like that means that it's running at higher than designed peak pressures inside the cylinder which puts more stress on every internal engine part. There will be more blowby, ultimately resulting in stuck rings. And as you probably noticed, the boat's a dog getting on plane.
